Help with drag suspension set up please
I was needing some input. Right now my 60' is the best of 1.50 on basically stock suspension on 28X10.5 e.t. drags. The only suspension mode I have is BMR subframe connectors. I am afraid of just throwing aftermarket suspension products on there and the car won't 60' anymore.
I was wondering what drag
shocks?
springs?
torque arm?
lower control arms?
are you guys running? What did you set your shocks at and what did you set you pinion angle at?
I would appreciate everybody's input and I'd appreciate if you posted your suspension modes and 60' times. Thanks
shocks?
springs?
torque arm?
lower control arms?
Front springs/shocks for sure. QA1 or Afco, I see Strange has a set for the front now...
Rear shocks maybe.
Good LCAs, non street car go with Rod ended ones.
Adj TA that mounts off the trans.
A good rear end for the high RPM dumps!
Rear shocks maybe.
