Drag Racing Tech
Line lock install Q's.
Old 01-25-2006, 01:55 PM
joblo1978's Avatar
Default Line lock install Q's.
I'm going to order Thunder Racings line lock kit, sais it comes with everything including pre-bent lines. Any special tools needed to install? Any purging necessary afterwards? I really don't do much work involving brakes except for pads and rotor replacement. Also, is the solenoid adjustable or anything? Is it a plug and play mod? How's the reliability of these things also and are they resistant to water? I wouldn't want to be driving down the road and my front brakes just lock up for no reason. Thanks!
John
Old 01-25-2006, 02:21 PM
LS1TECH Sponsor
Steve Burger's Avatar
Line wrenches help for the fittings. You will need to bleed the brakes after the install as you will have pulled lines.
Old 01-25-2006, 04:04 PM
joblo1978's Avatar
Can I just bleed at the caliper after installing the LL or will I need the scan 2 tool? I'm also installing some SS brake lines. I'm thinking about picking up some of Earls solo bleeders. I still can't find anything on how they work though. Will they make it simpler and easier?
Old 01-25-2006, 04:26 PM
BADFNZ's Avatar
You just have to bleed them from the bleed screws on the calipers.
Old 01-25-2006, 04:46 PM
Maggie's Avatar
Yes, the Solo bleeders will make it easier to bleed the brakes if you are doing it without anyone helping you. The Earls solo bleeders work like a one way check-valve keeping air & contaminates from aspirating back into the line. All you need is a catch bottle to recover the expelled fluid.
