How do I move my battery
I want to move my batterey to the trunk and i have a couple of questions about how to do it? Also what is the best kit to buy and where? What type of battery should I go with, memba its my D.D.? Is it that hard to do? Is it really worth it?
It is very easy, just buy the Taylor kit with the aluminum box( if you want to pass tech) and all the wiring for Summit, it's like $130. Do a search on some of the custom ways guys connected their stock wires under the hood to the new wires running to the back, and everything else is pretty self explanitory. The ground wire you get with the kit won't reach the seatbelt bolt so I just drilled a hole in the body behind the tail panel, and bolted it to there.
Restricted User
This is in my 98 TA
More info..
https://ls1tech.com/forums/drag-racing-tech/480741-battery-relocation-will-set-up-work.html
More info..
