How much HP to lift front tires?
how many hp does it take to lift front tires off the ground. i dont think im ever gonna but its one of those things i always wanted to do. just curious how many HP it takes
It is not always horsepower which brings the tires up the air. It is good suspension such as HAl shocks front (with front drag springs) and back, lower control arms, torque arm, bigger rear sway bar, decent conveter, etc.
like kent said it has alot of factors to it. I do it with 428 RWHP N/A in a 3336 pound car on stock rear suspension but upgraded front with a 4000 stall converter 3.23 gear and 26" tire
thats cool well im an m6, im assuming its do-able on a m6 with a strong rear sense i can launch whatever rpm i wanna dump it at. but i guess i need alot more power than my probably 350 hehe
I have done it N/A.
I dynoed the bird N/A a couple weeks ago, here is the dyno sheet:
http://www.bbbracing.com/genie/DynoDay32506/Dyno.jpg
182.18 rwhp
186.61 rwtq
Granted my bird is all about weight reduction, weight relocation and suspension... but if you want an actual HP .... then see above for my dyno #'s
182.18 rwhp
186.61 rwtq
With an M6
-12bolt and steep gears
-strong clutch
-sticky tires
-Torque Arm, relocation brackets, HAL QA1's
I bump 'em with 1.6's and stock springs/shocks but I just got QA1 springs/shocks so I'll see what I can do now
-strong clutch
-sticky tires
I was doing it with my 355 LT1 motor with only 361 RWHP at one point.
The suspension and 3500 stall were the bigger factors. Now, with the 385 LT4 Stroker motor putting down 432/468, traction is my biggest problem now. Anytime the car even comes close to hooking, there is daylight under the front tires.
Last edited by TWS; 04-11-2006 at 12:54 PM. Reason: Put down wrong number for RWHP
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
I did it with 325 rwhp at 3450 lbs in my Nova. Suspension, convertor (or clutch dump & rpm selection) and gearing is the key, along with TRACTION!
Derek
Derek
