need input on my set-up
ok guy, I don't post alot in here, so bear with me. I have decide to start with my suspension now. I was doin a cam but the horsepower gods didn't agree & my clutch took a dump. So since I sent everything back I figure suspension would be a better starting point this time. Here is what I should have on the car by the end of July.
Pacesetter Race LT's
TSP ORY
P/P 02' TB
BMR adjustable panhard
BMR non-adjustable LCA's w/relocation brackets
BMR boxed SFC
How much should these parts improve my times??
My current best is : 13.4 @ 104.7 w/2.1 60'
I'm also lookin at a UMI tunnel mounted torque arm w/o loop.
TSP ORY
P/P 02' TB
BMR boxed SFC
You dont need an adj panhard a non adj is all you need until you go with some big tires. Dont buy a throttle body either get your clutch fixed and buy some 16" rims and some good drag radials. I would buy
1. clutch
2. drag radials you should be able to cut atleast a 1.7 60 's with some BFG's
3. long tubes
4. relocation brackets if you cant hook and some lca's if you are getting bad wheelhop
1. clutch
3. long tubes
1. clutch
3. long tubes
1. clutch
3. long tubes
