mixed results with my qa1s Rs
changed from stock to qa1s R;s all the way around. now when i could get the car to hook i was cuting 1.7 60 ft. But now the car is squating hard and pullling hard to the right. Track prep sucked beacuse i lauched at 4k and cut a 1.7 and the nex run did the same thing and blew spun an cut a 2.0....
7 Second Club
if its pulling to the right and your front wheels are on the ground have someone check your steering wheel alignment... if your front tires are barely on the ground then you need to adjust 1 of your rear shocks...
also i was pulling 1.59s with stock front shock and springs. now that i went to the qa1s i could only get a 1.7 but it feels like went its hooking its making the car squat more and pull to the right
