Will spacers clear 15x3.5 Prostars w/o grinding?
Wasn't sure if I should post here or Wheels/Tires......mods, move if necessary.
Going to head to the track this week and my buddy has his front runners sitting in my garage. I was hoping I could throw these on without grinding down my calipers (just painted them a few weeks ago ). Will spacers do the trick? If so, what size do I need?
Stock wheel studs will work, I ran on them for a while with the 5/16th spacer. But from what I understand, the practice is very unsafe. I've since switched to the longer studs.
g
g
Yes, the whole point of spacers is to stop them from rubbing. I have heard some horror stories of people running stock studes with a spacer. If you get longer studs, you'll be fine. Just don't drive it like an ******* around corners, and you'll be fine.
