Will this suspension help
As of right now this how my suspension sits.I have Eibach sportlines springs.Sphon LCA', Recolatin Brackets,Panhard Rod,CE rear drag shocks.Planning on upgrading to QA1 R's with 275 spring in the front,and Sphon rear drag bar,removing front sway bar.Will adding these mods improve on my 60' right now car doesn't really wieght transfer?
BTLFEDSS
BTLFEDSS
The rear drag bar wont help you until you have a problem with your car twisting and lifting pressure off your driver side tire. Pulling the front may help alittle. Before sombody can recomend somthing for you we need to know what, motor, tires, converter and your currrent times.
Whats your launching technique and how many times have you ran the car? You should be able to do better than that unless you track sucks really bad. What kind of tire pressure are you running? You may not be able to do a full on clutch dump but you should ATLEAST be able to slip the clutch to some 1.7's. What all have you tried? When is the nitrous coming on?
__________________
__________________
