Drag Racing Tech
Advice on improving my 60 foot times?
Old 10-11-2006, 08:34 AM
vmax1500's Avatar
Default Advice on improving my 60 foot times?
Have a look at this video...
http://s97997631.onlinehome.us/temp/427bird/launch.wmv
This is launching off the transbrake running NA... the track prep was not great, however I still think there is room for improvement on how the car leaves...
The car is pretty light at 3300lbs RW... has a full drag suspension with all the good parts... 1.76 glide, converter is setup to handle a 300HP shot but still works OK on the motor... 3.73 gear... MT 28x10.5 stiff sidewall slick. QA1's are set to 1 up front, 5 out back and tire pressure is 11psi cold (no tubes).
Best NA 60 foot is a 1.50, best spray 60 foot is 1.39 with a 200HP shot when I had my 4.10's... best 60 foot with the 200HP shot and 3.73's is 1.43 (the same weekend as the 1.50 NA pass, I only got 1 spray pass in...).
Here's an in car video of the 1.43 pass... as you can see from the steering correction on the launch, there is some wheelspin...
http://s97997631.onlinehome.us/temp/...ep%2029-30.wmv
What suggestions would you guys make? I plan on getting a little more agressive with the tuneup... I guess it's possible the car might just need a little more power to help it get moving?!?
Old 10-12-2006, 05:04 AM
"All Motor 9 Second club member"
TXCAMSS's Avatar
Put a bigger tire on it and maybe try softening the rear shocks a bit if the track prep sux. The MPH has 9s written all over it.
Are your slicks in good shape?
Old 10-12-2006, 08:31 AM
02SOMWS6's Avatar
Can you put a trans break in it? For an all out drag suspension you should have a better 60ft. Maybe your converter needs to be flashed and footbreaked? Not sure I only know a little about auto's but my car is a stick with stock shocks and springs and I cut low 1.5 60ft's NA and in the 1.47 's on spray and my tires weren't screwed in so my 60ft's should get better next outing cause they were turning in the rim. I say it's the converter
Old 10-12-2006, 09:00 AM
6 & 8 Second Club
mrdragster1970's Avatar
I have never seen a converter that will work with a 300 shot and than work N/A.
My '70 1/2 only had a 175 shot and I had to have 2 converters. Just my opinion.
I can't see the video, so I'm just going on my experiance. Another vote for looser converter.
Old 10-12-2006, 03:42 PM
BigSteele's Avatar
damn i just watched those vids a lot of times
Old 10-12-2006, 04:35 PM
SScam68's Avatar
Have you tried calling MADMAN???
Old 10-13-2006, 06:49 AM
vmax1500's Avatar
I agree with you that it's impossible to have a converter that will do everything well
We'll see what happens when I put more spray to her !
Quick Reply: Advice on improving my 60 foot times?
