Chromoly vs Mild Steel
How much weight savings?
I have 01 f-body and need to get a cage.
I was thinking weld in 5pt instead of a 6pt to save weight with a swing out.
How much weight would I save with that style of cage......chromoly vs mild steel?
Thanks
Thanks
Thanks
Thanks
the right way to find out what you guys need to no is contact your division headquarters be it nhra/ihra they are the ones who make the rules ,or contact a competent shop who build cars ,also a lot of guys are calling roll bars cages this is also wrong [this is quite common]so when some one calls for quote first we have to find out what they are talking about :drivepro
heres a paragraph i made for the fast ls1 site [it is also post in ls1 tech a few times as people asked ] alot of people are useing the wrong terminoligy] ,a cage is a cage and a roll bar is a roll bar[a roll bar can have 5pts 6pts 7pts and8 pts,a cage can have 6 pt ,8,10 12pts] a lot of people call up for cages and their trying to ask for roll bars its a common mistake
,most cages are actualy are 6pt unless 2 diagnal bars go to tunnel or frame connectors[before everyone jumps on me the 2 side bars usually go to the front uprights so unless you have the 2 diags like i said and they are mandatory when a cage is put on plates[pge 209 of rule book see diag. read D] if its a chassis car[ ie chevelle,malibu,corvetteanything with a full frame under it]the cage then has to be mounted to the chassis and dosnt require the 2 diags to tunnel. what else is needed are ,a window net,padding anywhere drivers helmet can contact[pge 203], and the instaler should put tabs for required shoulder harness [so its bolted to spine bar and cannot slip off you in case of accident]and if you go faster than 9.99 a chassis cert that should cover the basics hope this helps.
and we have not done mild stel anything in like 5yrs,so C/M it is bob
When trying to figure the weight difference consider that MS has to be .118" thick wall and CM only has to be .083 so a CM rollbar is 70% of the weight of MS.
Example: if a MS weighs 75lbs. then a CM of the same configuration would weigh 52 lbs.
so the difference between that and the CM is @ 33%
we have wieghed it several times through the years, bob
