Gear and Tire Question
IM JUST THROWING NUMBERS AROUND JUST TRYING TO UNDERSTAND SOMETHING.
Example:You have a 28" tire with 4.56 gears and you run 1.3x's 60ft's 10.2x's@130 roughly your RPM through the traps is 7,400.
Now...You change to a 30" tire with 4.88 gears, what happens?
Do you 60ft better?
Will your ET drop?
Would you run the same?
Do you 60ft better?
Will your ET drop?
it would depend on what kind of tire or are you having trouble hooking now
30" are you planning on going to radials?cause that will drop your rpms also
Im not that great at explaining things.......
http://www.f-body.org/gears/
TH400
2.48 1st
1.48 2nd
1.00 3rd
28" Tire/4.56 Gear
6,700rpm 122mph
6,800rpm 124mph
6,900rpm 126mph
7,000rpm 128mph
7,100rpm 130mph
7,200rpm 132mph
7,300rpm 133mph
7,400rpm 135mph
7,500rpm 137mph
6,700rpm 122mph
6,800rpm 124mph
6,900rpm 126mph
7,000rpm 128mph
7,100rpm 130mph
7,200rpm 132mph
7,300rpm 133mph
7,400rpm 135mph
7,500rpm 137mph
30" Tire/4.88 Gear
6,700rpm 123mph
6,800rpm 124mph
6,900rpm 126mph
7,000rpm 128mph
7,100rpm 130mph
7,200rpm 132mph
7,300rpm 134mph
7,400rpm 135mph
7,500rpm 137mph
6,700rpm 122mph
6,800rpm 124mph
6,900rpm 126mph
7,000rpm 128mph
7,100rpm 130mph
7,200rpm 132mph
7,300rpm 134mph
7,400rpm 135mph
7,500rpm 137mph
On paper it looks exactly the same
TH400
2.48 1st
1.48 2nd
1.00 3rd
28" Tire/4.56 Gear
6,700rpm 122mph
6,800rpm 124mph
6,900rpm 126mph
7,000rpm 128mph
7,100rpm 130mph
7,200rpm 132mph
7,300rpm 133mph
7,400rpm 135mph
7,500rpm 137mph
6,700rpm 122mph
6,800rpm 124mph
6,900rpm 126mph
7,000rpm 128mph
7,100rpm 130mph
7,200rpm 132mph
7,300rpm 133mph
7,400rpm 135mph
7,500rpm 137mph
30" Tire/4.88 Gear
6,700rpm 123mph
6,800rpm 124mph
6,900rpm 126mph
7,000rpm 128mph
7,100rpm 130mph
7,200rpm 132mph
7,300rpm 134mph
7,400rpm 135mph
7,500rpm 137mph
6,700rpm 122mph
6,800rpm 124mph
6,900rpm 126mph
7,000rpm 128mph
7,100rpm 130mph
7,200rpm 132mph
7,300rpm 134mph
7,400rpm 135mph
7,500rpm 137mph
you cant go by that exactly it will depend on conveter and if he is switching from slick to radial or what not a regular slick will grow where a radial will not
and id be willing to bet that radials WILL be quicker and faster
