QA1 R Series VS Strange Coil Overs
am going to install Coil Overs on my 2000 Formula & have heard through the Grapevine that Strange Shocks seem to Out shine the QA1 Shocks on consistantacy & just over all quailty?
What is everyone experience with the QA1 R Series Coil Over Shocks? Good Bad
The Strange are cheaper but I am not worried about the price, I am more concerned with the Quailty & performance of the Coilover Shock I use?
Please dicuss?
Please dicuss?
Originally Posted by JoeyAnderson
I'm running QA1-Rs up front and I'll soon be using them out back, as well. Couldn't be happier! I have no personal experience with the Strange, however.
Did your 60ft time improve & how is the Quality of the shocks & do they leak at all? Also how is the handling if you ever drive on the street. Does the car feel solid at 70 on the hwy?
Who sells the strange coilovers on this board and how much are they compared to the qa1's . I have heard that strange was better also. This is the next suspension mod i want to do to my car. The best 60' i have cut is a 1.61 so i need some help,lol.
Retired Street Racer
I have the QA1 "R"s with 275lb springs up front. I couldn't be happier with them. Next to my big converter it is the best mod I have done to the car. The QA1 "R" and Strange's are similar shocks and will net close to the same results. Now if you were comparing an AFCO to a QA1 single adjustable, that's a different story.
Maybe you are comparing QA1-Rs to Strange Single Adjustables..
But Strange Double Adjustables, which would be QA1R similar are more expensive...
Originally Posted by skipperbisket
AFCO's FTW...and I bet madman agrees
That does not mean everyone has the budget to do it..
QA1 Rs are 185.00 Aprox
Strange DAs are 250.00 Aprox
AFCOs are 375.00 Aprox..
All in all, when you buy 4 of them.. it makes a huge number...
CARTEK Racing
I have the QA1 'R' guessing thats the old one as apposed to the 'F'
I have pulled 1.40 60's with them and 1.42's consistently, but now I am beginning to think that they took a ****. Before when set on the looser side I was able to blip the throttle and the nose flew up in the air, but last few times out at the track and driving around they have not been doing that. Before when set on loose the car would feel floatie on the highway, now it seems to be just as stiff as before.
I dunno... can they just go bad in a few weeks?
Maybe its time to upgrade to the 'F's
Originally Posted by Luis Castellanos
Stranges are not cheaper..
Originally Posted by WS6TransAm01
I have the QA1 'R' guessing thats the old one as apposed to the 'F'. Maybe its time to upgrade to the 'F's
How do the strange act on the street for hooking. Have to soften them up a bit in the rear compared to the track? I am more worried about hooking on the street with a drag radial than the track. The track I can tweek more, and then there is that VHT which helps..
I got a deal on a full set of strange SA that are waiting to go on, I just want to get to the track and see how they hook on my new Bogarts and ET streets then I want to start installing them so I can see how the car reacts with my sussp. Kinda waiting on a K-member up front also.
I may still return the front SA for some DAs up front.. depending.
