Drag Racing Tech
Comp. Engineering drag shocks
Old 01-11-2007, 03:55 PM
Taubr Unit's Avatar
Default Comp. Engineering drag shocks
I know a lot of people use eaither stock or QA1's. I know the 98+ have better rear shocks compared to my '94. How do Comp. Engineering shocks compare to my stock ones. I dont wanna dump $300 on QA1's for the rear but $80 for Comp. Eng. are do-able. Worth the money or not much better then stockers. I already got everything else (ta, panhard bar, sway bar, lca's springs) so a set of shocks will finish it all off. What u guys think.
Old 01-11-2007, 05:21 PM
gator's 99TA's Avatar
i just went 1.38 60' on the comp engineering cheapys. 3 way adjust. they work on a good track but i dont think they are nearly as consistent. i go as many 1.4-1.5 as i do 1.3 lol
Old 01-11-2007, 05:33 PM
kp
kp's Avatar
1.28-1.29 60's all day long on them here. Consistant enough to win bracket races with
Old 01-11-2007, 05:43 PM
Taubr Unit's Avatar
ok, nuff said. There sold for me. Thanks guys for no bullshitting around.
Old 01-11-2007, 05:57 PM
It must be a black ls1 thing
Old 01-11-2007, 06:42 PM
BADFNZ's Avatar
Must be because mine have worked great. No 1.2s or 1.3s, but plenty of low 1.5s on drag radials and absolutely no other suspension mods. I'd say they're worth $80.
Old 01-11-2007, 06:47 PM
Retired Street Racer
Matt D's Avatar
It is a black thing
Jerry,
You knew my black car's setup. I cut 1.46 60fts on drag radials, Cam only, 3300 raceweight. I will be putting them in this car as well. Make sure you throw an airbag in the rear passenger spring as well.
Old 01-11-2007, 06:48 PM
Matt D's Avatar
P.S.
BADFNZ, I love the signature
Old 01-11-2007, 08:01 PM
LS1TECH Sponsor
Jonathan@Tick's Avatar
1.2's all day long with the comp engineering shocks on drag radials! They probably have about 10,000 street miles on them now and still work great.
Old 01-11-2007, 08:19 PM
1.26? damn! what setting do you guys run? 50/50?
Old 01-11-2007, 09:19 PM
n2o
n2o's Avatar
1.5x on drs with the old setup comps on the back. I can't wait to try them out with the new motor.
Old 01-11-2007, 10:20 PM
Magnet's Avatar
sorry but i was wondering do i need adjsutables on front and back or just front? i'm a newb
Old 01-11-2007, 11:07 PM
Taubr Unit's Avatar
yea, what setting are they on??
Matt:
I do have a air bag in there. I got the eibach drag springs and it came with a bag, i got it set at 10psi. And i know your car hooked, iv seen it in action.
Old 01-11-2007, 11:15 PM
Matt D's Avatar
Matt:
I always had mine set on 50/50 and would pull the wheels on the street
Old 01-12-2007, 10:19 AM
n2o
n2o's Avatar
Front will help.
Old 01-12-2007, 10:22 AM
JoeyAnderson's Avatar
Yes sir... Jonathan's car hooks a drag radial HARD on these cheapo shocks.
His are set to 50/50 just like mine are.
As I search for more in depth ways to whittle my 60' down, I'll likely replace my CE Drag Shocks with a set of QA1s to match the front.
...but for now, I'll settle with my consistent 1.4x 60's with them and the 6spd.
Old 01-12-2007, 10:57 AM
looks like 50/50 is the setting that is most popular. i run that setting. i remember KP saying the same thing in the past
Old 01-15-2007, 02:12 PM
mthegodfather's Avatar
Where did everyone order there Comp. Engineering drag shocks from?
Old 01-15-2007, 02:20 PM
Taubr Unit's Avatar
speed inc has um. $79.99 a pair... There a sponsor on here -------->
Old 01-15-2007, 05:36 PM
Restricted User
98Z28CobraKiller's Avatar
What options are there for the front suspension? I spent all of my money and didn't do the research on the suspension. I bought a set of SLP Bilsteen's with springs and everything all the way around before I knew any better. I went out to the track for the first time last Wednesday and it was ugly. The best I could muster was a 12.35 @ 122 MPH w/ a 2.04 60'. LOL. Pretty sad. I am 325/15/50 Nitto DR's and I had to let out in every gear as I had absolutely no traction anywhere. When I hit 3rd (M6) the car went sideways (pretty scary as it was my first time getting sideways in 3rd) on the first pass. My second pass was even worse. I went 12.85 @ 116 MPH. I actually spun so bad when I hit 3rd that I never got traction at banged the rev limiter. Shifted into 4th and bogged thru the traps. After that I decided that I didn't need to run anymore until I fix the suspension. My raceweight is 3450+330lbs (worth of me). I have no wheel hop at all. I have an adj panhard, non-adj torque arm (it was free) and tubular LCA's right now. I would love for some of you "dead hookers" to give me some pointers. I really need to do something on the cheap for now as I am kind of broke at the moment.
Here's my question, can I salvage any part of my current Bilsteen setup? Is there a soft front shock/strut that I can get cheap to help transfer weight? My GTO (dialy driver) squats when I hit the gas, the Z doesn't move any weight at all to the rear.
Thanks in advance.
Quick Reply: Comp. Engineering drag shocks
