what size slicks are you running
asking for slicks only what size are you guys running and whats the tallest tire you can fit safely under our cars? mainly want to know the width and height and if 29's will fit?
No one said they fit perfectly... mine (present/old set-up): rear-end narrowed 1 1/4", BFH mod, cutting fender well, cutting off bump-stops, cutting lower half of 1/4 panel... etc. Once done looks great.
New set-up (coming this spring): Moser 9", 3" narrowed each side, mini-tubbed, new perches, new spring (150lbs). Should be able to fit 15x12's, with some 30x10.5Wx15, lowered right on top of the tires.
Size of wheel matters. You can do: 30x9x15, on 15x8 wheels, they would come close to fitting. Doubt you'd be able to lower it much. You can buy perches from Wolfe that would give you a ride height adjustment.
David
David
