How to remove front bumper support on a Z28?
Re: How to remove front bumper support on a Z28?
Yeah i agree pulling the cover would make it alot easier. And a little tip on removing the platic fastners that hold the cover on, get a claw hammer and pull them like you would a nail. total of 8 10mm bolts that hold the cover on plus the plastic ones, then 6 13mm nuts hold the support on. Good luck.
Phil
Phil
when you pull the cover off there is 1 bolt on both sides that are a PITA to get to, pull the headlights out it makes it a lot easier.
hook one end of a chain to a tree, the other to the bumper support. Throw that biotch in R and nail it. You will shed alot of weight that way.
