Drag Racing Tech
Thunder racing Mid mount ?
Old 12-02-2007, 10:03 PM
empire_619's Avatar
Default Thunder racing Mid mount ?
I am about to buy a mid mount for my car. I have a question do i need some sort of spacer on the flywheel to compansate for the thickness of the mid mount plate?
Old 12-02-2007, 10:19 PM
RAGENZ28's Avatar
I think it is only 1/8" thick so you'd just put an 1/8th" washer between the converter and flex plate.
Old 12-02-2007, 10:26 PM
empire_619's Avatar
cool thanks man...
Old 12-02-2007, 10:38 PM
RAGENZ28's Avatar
cool thanks man...
I looked it up and it says it is .100 thick, so that should work.
Look at thunderracing.com at he midplate it lists the thickness at .100, so just going by what they say, you can always give them a call to check what they recommend.
Or ask madman himself since he's always willing to help.
Old 12-03-2007, 09:00 AM
T Pizzle's Avatar
I have one and it is only .100 thick. Should not need to space anything at all
Old 12-03-2007, 09:33 AM
RAGENZ28's Avatar
Don't listen to that guy he drinks a lot of beer and smokes crack and has been hit one too many times in a bar fight
Yes, it is only .100 but remember some converters don't engage as much as others and running a .100 washer between the flex plate and converter (as long as the bolts are long enough) will help keep the converter fully engaged.
I'd personally ask the person who makes the midplate or ask the converter company. That way you won't have an issue with a warranty if you have one.
