lowered car and drag tires?
im lookin at gettin some 15x10 prostars 7.5bs (already have 15x8s 5.5 with 275-50 ET DRs) and some 28 10.5S for the M6. i have all the adj SPOHN suspension so i can center the rear no prob, the real question is will the i have to worry about the fender comming iton the tire?? thanks yall
Also, with the car slammed tq arms hit floorboards, rear ends kiss fuel tanks(9 inch)
325/50, no mini tub and lowered really does not compute. You hit a bump running a 100mph, cut a tire and you will be in trouble.
ALso with a slick you have to allow for tire growth
David
David
these are some of the thoughts i had as well.
i have done extenseve BFH and air hammer mods to get the TQ arm and bracket to clear the tunnel....... ended up with 2 big holes in the body.... been that way for years i still need to fix them. that will come with the carpet out, when the cage goes in.
If so what set of holes is the tq arm mounted in?
David
