Drag Racing Tech
12 bolt+1.4 60's+ spacers?
Old 09-02-2003, 05:29 PM
DriveATransAm's Avatar
Default 12 bolt+1.4 60's+ spacers?
is it ok to run spacers on my strange 12 bolt? i believe the studs are hardened (not really extended though)...itll only be a handful of passes. 60's will be in the 1.4 range or 1.5 if i cant hook well
Old 09-02-2003, 05:38 PM
Colonel's Avatar
Default Re: 12 bolt+1.4 60's+ spacers?
I've always ran spacers (3/16") on my '00 (1.3x 60s) with no problems. Just make sure your studs go up into the lugs far enough.
Old 09-02-2003, 05:46 PM
are 3/16" the bigger or smaller ones?
the lugs are the same length as the stockers...they just have threads all the way to the end and im sure they are hardened.
Old 09-02-2003, 08:39 PM
I can shift faster than you.
Jason99T/A's Avatar
1.43 60' and rear spacers with no issues.
Old 09-03-2003, 01:10 AM
Colonel's Avatar
3/16" are the smaller ones.
