404 lq9 numbers w graph
The car is back to running! Go it tuned today, only has 700ish miles on it, and put down 436rwhp 424rwtq on a SAFE tune....
Overall I am happy, the HUGE thing is that the car drives so well!! I cruised home in 6th gear@1450rpm and its nice and smooth. I do have to stay in some gears a little longer, but with a cam this size its to be expected.
Heres the rundown thus far
TSP 404
Diamond Pistons -10cc
Scat rods
Eagle crank
Stock Rockers
Thunder Racing pushrods
Ford 42lb injectors
Racetronix fuel pump/harness
TSP stg 2.5 ls6 heads
TSP dual valve springs
LS6 Intake/Ported Stock throttle body
1 3/4in Headers(American Racing)
American Racing Catted-Y
FMS Cam 24x/24x 63x/62x
Stock balancer
and other than what is in the sig that is all.....
Let me stress how AWESOME the car drives just cruising around!!!
Once I get some better heads, a fast 92/92, and some larger headers I think it will run very well.
Here is the graph:
The torque it carries is awesome....
TSP 404
Scat rods
Eagle crank
Stock Rockers
Ford 42lb injectors
Stock balancer
Here is the graph:
I'm totally with you on not living off dyno #'s. The setup is fresh and maybe the tuner did leave a bunch of power on the table.
I just know if we would be looking for some issues if we seen these kind of #'s on our dyno. There are cam only combo's that make this much power with cams similar or smaller then what you have listed.
The car should be in the 470+ range with what you have listed even with a conservative tune.
I hope it runs good for you at the track.
The graph is a little hard to see, but it seems to peak around 6K which is very early IMO.
this is can be due to the cam installed incorrectly or a restriction, and though the intake is some what of a restriction I do not feel it would cause this in your case
The A/F is hard to read, but it also seems to be on the rich side which could cost some power.
maybe some cam experts like Pat G can add to this
please understand that I'm trying to help and not tear your setup down
The parts all look good, but something is causing it to not make the power it should.
1 Post
Well there is a heavy *** drive line and gears eating up some of his numbers. Maybe the clutch was slipping too ?? At any rate a ported 92 from Ron at Vengeance and a 95mm tb should add about 25 rwhp to the mix. N/A tune vs Nitrous tune would probably pickup another 10 so add 35 rwhp to the mix and its still low. I would have the tune looked at just to be sure.
At any rate I am glad to hear that she runs so smooooooooooothly !! Now with that being said can she still run just as smooth with a few adjustments to your tune to get her to make more power ?? Power or drivability ?? Decisions, decisions. How about a cutout ??
Yes the tune is FAT, I wanted to be on the way safe side, sometimes here near the coast water gets in the gas, I dont want to take a chance so we left it fat. Im going to check a few things today, but I really think its airflow thats killing it, its a big cam and im not running a very good int/exh setup for a 400ci motor. The a/f is around 12.5.
The cam was installed correctly, dot to dot as it should have been.
I dont believe the graph shows any signs of clutch slippage, and I would be pissed if it was, its a Cartek with 8k on it, there should be no issues there.
The driveline is HEAVY chromo d/s, 35 spline axles, yea its got some weight.
Im going to check a few things today, and may hit the dyno back up and see if it makes a difference.
Jon
Jon
thanks..I did not want you to think I was tearing on you. The setup looks good besides some power being left with an intake / TB.
try another dyno if possible or hit the track and see how it runs
good luck
good luck
it could be as simple as the intake, but I have used them in the past and still not seen a peak that early
being a bit rich and depending on the timing there is power there
balancer is worth a little power
still overall it would be low for a 6 speed car with your setup, but some dyno just tend to read very low
EX: my dad H/C 90/90 A4 car makes 431 rwhp with a 231/237 cam and pulls cleanly to 6800 rpm
track it for now and see how it goes or get an intake / TB and retune it before digging deeper and see how it ends up
