My 408 Dyno #'s! Help!!
Old 12-09-2008, 01:57 AM
thecamaroguy98's Avatar
Exclamation My 408 Dyno #'s! Help!!
My 408 dyno'd at 479 hp @ 6210, 445.7 tp @ 4560.
My set up:
Eagle LS1 4.00 Stroker Crankshaft
Diamond Racing Forged Pisons 4.010 bore 4.000 Stroke Flat-Top -2cc
Cam: 248/254 .625"/.622" 112 LSA
Heads: PRC Stage 3 LS6 Heads 2.08/1.60 Valves 64cc Chamber
LS7 Lifters
Fast 92/92
1 7/8 Hooker Headers
I was hoping for 500, I'm pretty happy maybe a little dissapointed.
I was thinking after I finish the exhaust (td's mandrel bent) & get the Fast intake ported I could break 500. Do you guys think thats pretty reasonable?
I was also thinking of selling the PRC's for some TFS 235's
Old 12-09-2008, 01:59 AM
I forgot to mention...This is through an M6 with a 10 bolt. The next dyno will be with a 12 bolt.
Old 12-09-2008, 03:44 AM
Abdullah's Avatar
My set up:
LS7 Lifters
Fast 92/92
i would say try to either get the PRC 2.5 LS6 heads or hand touched up (by a good porter) TFS 235cc heads. also raise the compression to 11:1 or up to 11.8:1.
Old 12-09-2008, 04:57 AM
GMCHammer's Avatar
My set up:
LS7 Lifters
Fast 92/92
I would get the Intake/TB ported first! Then slap her back on the dyno. If your not happy with the numbers go with the TFS next!
Old 12-09-2008, 07:24 AM
Restricted User
98Z28CobraKiller's Avatar
Or an AFR225. 235 cc on a 408 is not neccesary. Specially if you arent going to spin it over 7K RPM.
Old 12-09-2008, 07:27 AM
the_merv's Avatar
LS1Tech 10 Year
Isn't that a 404ci with that 4.010X4.000 setup?
Old 12-09-2008, 08:06 AM
built408's Avatar
Yap, thats not a 408
Old 12-09-2008, 08:08 AM
edcmat-l1's Avatar
That's pretty low, esp the torque numbers. I'd ditch the heads for some TFSs
Old 12-09-2008, 09:11 AM
Restricted User
2001 Pewter WS6's Avatar
The TFS 235's work really well... What did the rest of you exhaust consist of???
Old 12-09-2008, 09:13 AM
rpmauto's Avatar
very similar to my results, i just got some 1 7/8" headers, after next season a better cam and some afr heads should make over 500 easy.
Old 12-09-2008, 10:51 AM
White_Hawk's Avatar
Got the dyno chart? Might be something on there one of the guru's here could spot.
-Geoff
Old 12-09-2008, 10:53 AM
ndfrsd6's Avatar
with 241 heads 90/90 setup 1 7/8 hooker headers same cam my 402 made 500 rwhp and 469 rwtq .....with bigger heads and cam i know i have a lot left on the table ....but the budget comes into play LOL...
Old 12-09-2008, 11:12 AM
When it was dyno'd it had Flowmaster Super 44's on the collector of the header. This spring it's going to a custom exhaust for a mandrel bent 3" setup over the axle...
I'm thinking that the exhaust setup probably hurt me a lot
Old 12-09-2008, 11:14 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Something else isn't right here. With a GM MLS head gasket you'd be netting about 11.6:1 or with a Cometic .040" you'd see about 12.0:1. What octane gas are you running? Who tuned it? What does the timing table look like? What's the air/fuel? Any knock retard on a scan? What Y-pipe and catback?
The last combo we engine dyno'd with the exact same setup made 625hp/585ftlbs. I'd highly doubt you're seeing 25% loss to that drivetrain! Let's see a graph and maybe a scan of the car and we can figure out what's going on before you dump $2400+ on heads.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 12-09-2008, 11:23 AM
Matt,
You have a PM, since this is a TSP Motor.
Old 12-09-2008, 12:55 PM
-Geoff
I have no scanner, but I'll see what I can do.
Old 12-09-2008, 01:12 PM
Cokeroker's Avatar
Default My 383
383 with 241 heads 90/90 setup, TSP Giant Cam (622/622), Pacesetters, M6, Ford Nine Inch on 325/50/15 MT, mine made 497/453 at the wheels.
Old 12-09-2008, 01:16 PM
What wasn't mentioned is that the numbers are from a Mustang dyno. Between that and the Flowmaster exhaust, the numbers aren't far off from what you'd expect on a Dynojet with a better exhaust setup IMO.
__________________
Old 12-09-2008, 01:59 PM
edcmat-l1's Avatar
Ah, yeah. The Mustang could def make a big difference.
Old 12-09-2008, 02:14 PM
WS-Sick's Avatar
The fact that it was on a mustang dyno should have been mentioned in the original post. There is nothing wrong with those numbers. I'm sure more power could be achieved with some changes others have mentioned but those numbers seem right for your particular setup on a mustang dyno.
Quick Reply: My 408 Dyno #'s! Help!!
