Prepairing for Dyno Tomorrow. What should I check?
Old 03-12-2009, 08:46 AM
corvet786c's Avatar
Default Prepairing for Dyno Tomorrow. What should I check?
Just as title says. Should I lower tire pressure it is at 35psi. Anything else should I check to get a good reading for best results? Thanks
Old 03-12-2009, 08:59 AM
LS1 Tech Administrator
Patrick G's Avatar
New fuel filter, clean air filter, fresh spark plugs, fresh O2 sensors, clean fuel injectors, oil topped off, belts in good shape, coolant level checked. Sounds pretty obvious, but you'd be amazed how many vehicles come to dyno with tons of preventative maintenance left to do.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 03-12-2009, 09:05 AM
allngn_c5's Avatar
By doing everything Pat suggests then your car should make as much power as possible. Nothing to second guess, well if I would've done this...you know.
Old 03-12-2009, 09:40 AM
corvet786c's Avatar
Thanks Guys, I had explained to the dyno guy that my MAF senor was very dirty from oil of K/N Filter it was running 13.1-13.5. Si I cleaned it last night, cleanined filter hopefully I can get that 400 mark and a 12.8 A/F ratio.
This is the first time I cleaned The MAF since I had the car about two years ago.
Old 03-12-2009, 09:43 AM
corvet786c's Avatar
This should be a Sticky.
Old 03-12-2009, 12:37 PM
thunderstruck507's Avatar
also check your tranny mount and torque arm stuff...i think my tranny mount was loose and caused me to bust a tailshaft housing
check lugnuts for torque, play in u joints, make sure you see WOT, ect
pretend its life or death your car is perfect...
