Bolt on 01 Z06 378rwhp, Bolt on 2002 Z06....404Rwhp
Old 11-13-2011, 04:13 PM
RickClarke23's Avatar
Default Bolt on 01 Z06 378rwhp, Bolt on 2002 Z06....404Rwhp
Well took mine and my Boss's 01 Z06 to dyno last night.
My boss's 01Z with 66k Dyno'd 378/362 with A Callaway intake, LG lontubes/off road X pipe, a B&B Route 66 Cat-back, my Tune, TR6 plugs and new GM wires, and a Monster clutch/flywheel. His car liked 25deg of timing and 12.4 af's. Dyno'd 3 times and all were around that number. His first pull was 371 then we made slight changes to the af/timing.
Next we strapped my car down. Which is a 2002 Z06 with 45k. Mods are a Halltech Venom II, XS power stainless longtubes/ Off road X, Factory Titanium Catback, TR6 Plugs, New GM wires, Stock Clutch, Slight TB porting (not much at all) and my tune. First pull on 25 Degrees of timing and 12.3af was 402.1 hp 369tq. Added 1 degree and pulled a little fuel. Next pull was 404rwhp with 26.5 degrees of timing.
Video
http://www.youtube.com/watch?v=gSppGUK96PM
Im giong to be doing a Fast 92, Comp 918 springs, 1.8 rockers to see how much power we can get out of the car. also will try and get some track times asap...
Old 11-13-2011, 11:51 PM
itsslow98's Avatar
Have you run each other. Id be willing to bet its dead even.
Old 11-14-2011, 08:13 AM
SideStep's Avatar
What correction was used on the pulls?
Would you post the Dyno-Graphs?
Old 11-14-2011, 08:19 AM
No we havnt. His car has drag radials and a clutch so it would be really close I'm sure. My pilots are a bit old and fry 2nd from a roll.
Old 11-14-2011, 08:21 AM
This was sae. I dont have the graphs but I will try and get them. I am a tuner at unlimited performance in south Texas and this is the dyno we regularly use. These were just our personal cars. I should be able to get the sheets today if I have time.
Old 11-14-2011, 08:49 AM
SideStep's Avatar
Sweet.... thanks!
Old 11-14-2011, 09:05 AM
HioSSilver's Avatar
Good Job! Keep working on that ls6 and it will reward you. Mine makes 426rwhp (dynojet #'s)....full bolt-on.
Old 11-14-2011, 01:45 PM
Yea I am going to be doing some 1.85 rockers and comp 918s along with a fast 92.
Old 11-14-2011, 02:18 PM
Strokinit383's Avatar
Good numbers. Just out of curiosity, why would you run a colder plug like the TR6? Are you spraying? Seems like you might be better off with the TR55.
Old 11-14-2011, 02:29 PM
HioSSilver's Avatar
I just changed to a ported fast 90 over my proted ls6 mani and picked up 13whp and it carried the power longer so bumped the rev limit to 7000. I have Harland Sharp rr at the stock 1.7 ratio, not really a change but it did seem to run "free'r" at high rpm's. I would be very interested to know what a set of 1.8 or 1.85 would do on a ls6. PM me those numbers or just continue this thread if you would please. You might want to try some timing in the mid range to get tq up. I have a graph of mine before the fast90 swap for comparison.
Old 11-14-2011, 02:46 PM
I am going to be spraying in the future yes.
Old 11-14-2011, 02:48 PM
I will deffinitely update the thread when I do get those in. Also for some reason my car didnt like any more than 26 degrees of timing at peak torque and would have some clatter. Nothing showed on the knock sensors but I heard it a bit. So I backed off a bit until 4500..
Old 11-15-2011, 01:20 PM
Buckwheat's Avatar
I have comp 1:85 rockers in my 01' and made the numbers in my sig through cats. I figure 10 more peak without. While I'm sure the rockers increased my peak numbers, they really woke up the low to midrange torque. I don't have stock baseline numbers to compare to so just going on sotp.
Old 11-15-2011, 01:32 PM
HioSSilver's Avatar
I could see that happening on a 01 ls6 with the smaller cam.
Old 11-15-2011, 01:51 PM
I expect about 7rwhp from the 1.8 rockers/valesprings. Then another 9 from the fast 92 when I do it.
Old 11-15-2011, 02:17 PM
HioSSilver's Avatar
I ported my fast90 and picked up 13whp and 10wtq over a worked ls6 mani. The dyno graph above is with out the fast90
Old 11-15-2011, 04:02 PM
Buckwheat's Avatar
That's one stout LS6 you got there. I was kicking around the idea of having my heads ported/milled this winter and going with a fast90. That would probably put me well over 400 rwhp with the stock cam.
Old 11-30-2011, 03:54 PM
HioSSilver's Avatar
Thanks Buckwheat. Any updates on the rocker swap?
Old 11-30-2011, 04:09 PM
Yes rockers are in. Just waiting to get a chance to get on the dyno. Feel a small seat of the pants.
Old 11-30-2011, 06:49 PM
LSX Mechanic
Damian's Avatar
I'd use the PSI 1511 Maxlife beehive over an unreliable/highly prone to break 918.
Pretty nice #'s out of a stock internal Z. If you want another 15rwhp and faster revving, put a Fidanza alum flywheel in it.
