LS6--->LSX Intake Bolt-On Dyno Results
Old 03-29-2004, 08:55 AM
steve-d's Avatar
Default Re: The need to retune the car after LSX install??
Hello,
If you have a H&C car w/all the goodies and a good tune, will it be necessary to retune it after upgrading w/the LSX???
Its my understanding that if you've had the AF ratio set to around the generally accepted performance ratio of 12:1, then the computer will recognize the newly increased airflow and adjust accordingly. IOW, it'll increase the fuel flow to bring the ratio back to 12:1.
Am I missing something? Just thought I'd ask the collected brain trust about this as this is exactly where I am regarding an LSX install next week.
Best Regards
Steve
Old 03-30-2004, 02:08 PM
Smoke_ur_5.0's Avatar
We didn'y pick up anything with the 78mm LSX on a bolt on car until we tuned it. Picked up 6rwhp and 7rwtq but pick up 15hp and 10tq in the lower rpms.
Old 03-30-2004, 02:33 PM
Zero2Sixty's Avatar
Yes it seems that tuning really seems to be helping ppl out with the LSX.
Glad to see you picked up some rwhp.....
Old 03-30-2004, 03:49 PM
JurisAg02's Avatar
isn't this exactly what happened with the Weiland intake users also?
Old 03-30-2004, 04:36 PM
Speedfreaks101's Avatar
I don't beleive that the LS6 intake leaves a lot to be improved on. GM designed a great intake and for an aftermarket manufactur to improve upon it in the rpm range that most of us use will be quite a feat IMO. Look at the sheetmetal versions in the aftermarket. How many of them boost low-midrange torque? None! They do boost high rpm HP though, but that is the desired rpm range. This is beacause of runner length, shape and plenum volume. I do think that the LSX is a superior intake but for a bolt on car it is not the wisest money spent. That 800.00 would go a long way to a nitrous kit, or even 1/3 of a 12 bolt. If you are already cammed with ported (or aftermarket) heads then it would show its value, but even at that point I think you would be better off with a 90 mm version. Not a flame jusy an opinion.
Sorry to hear about your numbers.
Later,
Bart
Old 03-30-2004, 04:49 PM
Cobraeater's Avatar
Default LS1 Edit Graphs
Originally Posted by Iv_z28
Well, it IS pretty obvious from your grath that your A/F ratio have gone up with the LSX.
If you are saying that your graph is BEFORE the tuning, and tuning didn't change much, then I would still check if, f.e., the timing is right. Why don't you post the graph after tuning?
Here's the graphs from LS1 Edit.
http://www.cobraeater.cz28.com/cgi-b...20Edit%201.jpg
http://www.cobraeater.cz28.com/cgi-b...20Edit%202.jpg
As you can see by the 13-15 run the a/f was around 13.0 and the hp and torque was the same as before the tuning.
So tuning didn't help.
Old 03-30-2004, 06:28 PM
Revelation222's Avatar
Good lord, that has got to suck after all of that trouble. Sorry to hear that, bro. Lets hope you see the gains later, after cam and/or heads. But how would we really know you gained anything extra over the LS6 then either.
Old 03-30-2004, 08:21 PM
GrannySShifting's Avatar
it looks like it actually lost a tiny bit of low end. We had dissapointing results with one as well
