Ls3 416,TEA TFS 245, EPS cam
After speaking to Geoff and tea they both advised me the 245s would be a better choice. They have more experience with them so I let them chose. If I would have built the block around the 245s the compression would have been closer to 12.1. I originally was using 61cc 243s but figured I'd be leaving alot on the table. So I contacted Geoff and made the order.
Hmmm... just when I thought I was decided on the 235's LOL. But yeah if TEA recommended the 245's that is good enough reason I would think (knowing your setup, etc). I may have to call and talk to them as well, I was thinking of going with TEA anyway.
#32
The individual doing up my new TF's is going to weld in the chamber in an area that does "not" affect the final flow numbers. The way it is explained to me any milling is going to hurt flows numbers as you shroud the valve in.
#34
Now that I think of it I had trouble sealing the headers. I was using oem multi layer but still having leaks. So I bought sbe copper gaskets that are a little thicker. Holding the gaskets over each other the sbe were about 3/16 to 1/4 smaller I.D. Than the oem. Would this be causing a restriction worth fixing?
#35
#37
I'm not sure if I'm in the right section, also posted in fueling and injection. About 1 week after the tune the car started acting up. First, I noticed 1 out of 5 stop and go's the throttle would have a dead spot (from 0% to 30%). It didn't bog or act like anything was happening. Second symtom was lean idle 22.5 on innovate lm1. It started to have a small miss. I started testing, I pulled the plugs and they were whitish brown, with an green tint. All grounds were checked, fuel pressure, spark, injector pulse, compression 200-210, and valve springs, I still could not find the issue.
Now it's hardly running. Afr is extemly rich. With a bad miss and it stalls now. I pulled the plugs again to change them, they were black. I installed a new crank position sensor but still it's not better.
One thing I did notice is the fuel pressure go's from 65 to 40 instantly when I prime the system. But seems to hold 65 when idleing. It has a racetronix pump with Hotwire kit. I can't seem to diagnose the problem. But it seems to be getting worse. Any help would be appreciated. I'm out of ideas! Sorry for rambling
#39
Solid numbers, we always want more....... but I am sure Geoff looked from every angle while developing your cam and tuning the whole package so I doubt there are more than a couple rwhp/twtq hiding out somewhere. Wait on some good weather and go see what mph you trap in the 1/4, thats what its all about with a "street" car if you like to play around on the street
#40
Did you fix the problem ? Did you dyno it again ?
