L33 240sx dyno results 347whp/325 wtq
I had my car dyno tuned a few months back. Seems to be missing some torque. Its a rebuilt 5.3 liter L33 with 243 heads. C6 corvette exhaust manifolds, ls1 intake, tr224 .563 114lsa cam, 2.5" dual exhaust with highflow cats and no mufflers just some import silencers.
Edit: the tune ended up being too lean is why it was missing torque. I bought hptuners and a wideband retuned it myself.
This dyno sheet is before adding the high flow cats and swapping to an LS6 intake.
Here's the engine bay.
Here's the car.
Here's the car.
Local tuner here in houston. I actually was thinking the same thing. I asked about the dip and he said afrs and timing were good but I have done some tuning just not hp tuners and my thoughts were something in the tune wasn't right.
I thought that dip was sort of inherent in some cams. I think the manifolds are probably hurting the most - I'd think you'd pick up close to 40 rwhp and 40 tq or more since you have a cam. Then again, I'm not sure how efficient the LS3 manifolds are, so i could be off base.
You could buy shorty headers and a LS6 intake...that would net you some good HP.
I dont know but I read somewhere that those kind of ''CAI'' you have maybe hurting the HP too. I dont if you could fab some sort of scoop under the car or isolate the CAI from heat. Just some thoughts
Your numbers actually look really good. I am assuming this is a stick car. If it is not and has a stock converter it is going to feel very soft on the bottom end. The L33 is no a low compression motor, 10.0 or so. The cam is a hair large and that is causing the dip. Look at where your tq peak is. Kind of tells the story. I doubt it could be tuned out if the guy is competant and had the fuel and timing right. Knock usually shows a little differently on the dyno. That dip is very typical of over cammed LSX's. I had this motor in my 06' Silverado with a smaller cam 215/223 .609 .615 lift on a 112, lightly ported heads, similar intake, headers, cattless Y and other small things. I only made 330/325rw which was up about 75rw from with just exhaust. I was running out of fuel at 5,000 however. Like the other guys said, get a LS6 intake and any kind of header you can on there, do an underdrive pulley and figure out your DCR. I am guessing it is down in the very low 8's. If you used the stock head gaskets then you can replace those with some .040 cometics and get your tq up. Over all I would be happy with what it is making the way it sits. Do the suggested mods and you will be very happy.
MASS seller approved
ls6 intake, headers, and stall all would help. 243 heads have 64:45 cc's while 5.3 heads have like 61-62 cc's. no need to change cam but i would mill heads which will increase compression, torque and power .
What you guys are missing though is that the L33 got new flat top pistons for sure with no valve reliefs and I am pretty sure longer rods. So there was a half point compression bump over the LM7. Stock, the L33 has 9.9-10.0 compression. They changed the cam slightly also. He does need more compression for that cam though. I am pretty sure he can get most of it with a gasket change.
Yeah its a t56 so no need for a stall, lol. I think i fixed my problem. I picked up a 98 ls1 engine almost complete. The only downfall is the 806 heads. I will do a basic rebuild and swap my 243 heads and tr224 cam onto the Ls1. Should be a bit stronger.
