"The Mongoose" - 1 3/4" Headers To 1 7/8" Headers (447 rwhp and 431 rwtq)
Old 04-27-2016, 08:25 PM
  #41
Rise of the Phoenix's Avatar
Was spark advance played with given the better flowing headers? If everything is truly identical, I think your exhaust is too good compared to your intake and your overlap is causing you to suck intake charge out the exhaust at high rpm like the venturi affect. You don't see it at lower rpm cause the air isn't moving as fast. If you have a chamber with a super efficient exhaust and suck through a straw, some of the intake charge is going out the exhaust cause its lower pressure. I'd bet money you pickup power with a smaller cam with less overlap.
Any way to fix that without a cam change? Would a FAST setup fix it and allow me to run this cam?
Old 04-27-2016, 08:38 PM
  #42
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
It gives you a much better shot, more air in more air stays in the chamber. Don't take what I say as gospel though, I just get paid to think analytically and rule out variables until a solution is reached. In this scenario it seems reasonable that the combo just isn't working together and I think valve events and the speed of the airflow is coming into play. Its all about cylinder pressure in the end and i think the cam with that i/e isnt as good as it could be. It's a Tick cam, was that when Martin was working there? If so what does he say about the change in the graph from the header swap?
Old 04-27-2016, 08:48 PM
  #43
Martin hasn't weighed in yet. I hope he sees this and does. What you are saying is basically what Kent (builder and tuner) is saying. He said the intake is acting like a velocity stack in the higher RPM'S and it just cannot keep up with the heads and headers. Seems as if the valve events are not optimal for this setup. A different cam on a 112 or 113 LSA may not have this issue of the intake being such a restriction.
Old 04-27-2016, 10:53 PM
  #44
nmass399's Avatar
Your running it in speed density correct? Look at the new tune in the ve table vs the old tune with the other headers and see what it looks like. Is it putting more fuel in or less at those rpms?
Old 04-28-2016, 07:00 AM
  #45
Yes, it's in Speed Density. I'll find out. What could that tell us if it's putting in less or more fuel at the higher RPM's?
Old 04-28-2016, 07:20 AM
  #46
ddnspider's Avatar
I cant help but notice the thread down from falxzzr that seems to have similar issues at high RPM. Same dyno and tuner, and if the AFR and spark are what they are, is it possible the dyno has an issue at high speed or is there examples from that dyno where they'll pull cleanly to something highish. He also has a new motor, was the same builder the one who put your cam in?
Old 04-28-2016, 07:58 AM
  #47
jmilz28's Avatar
I think you're on to something here. I'd take this car to a known reasonable dyno and see what it puts down. My thinking is there is something fundamentally tweaked with this dyno.
Old 04-28-2016, 08:01 AM
  #48
kinglt-1's Avatar
I just do not see the LS6 choking power per SE. It's is documented to have made well into the 450whp range with a vast range of H/C 346 setups over the years. Will a Fast make more power yes, but the LS6 is not a bad piece. If we were talking about the LS1 intake then yea this theory would seem plausible. The motor should still peak around 63-6400 even with the LS6 and carry.
I think the dyno is wacked...take the car to a different one. Or head to the track and see what it traps.
Old 04-28-2016, 08:02 AM
  #49
I see what you're saying about FALXZZR and his dyno sheet. His graph, like mine, stops making power before it theoretically should. That could be an issue with the dyno, who knows.
In regards to Kent, who did my cam and heads swap, as well as a lot of the tuning, I do not doubt his ability at all. He's done tons of LSx builds and has an 8 second LSx himself that he built and tuned.
Old 04-28-2016, 09:23 AM
  #50
9sectruck's Avatar
The car feels awesome on the street. The car does not lay over on dyno nor does it sound like it has any issues during the pulls.
There may be something with the dyno settings that is causing low hp numbers in the upper rpm.
The graph from one pull to the next pull with header swap and new mufflers. (no dyno settings change) seem like it falls off to fast. Yes the dyno may be off but the car def lost power up top.
As for a clog or restriction on exhaust there is no smell or noise to indicate a blockage.
The car did need more fuel on big end to get back to the 12.7afr after swap was done. Timing has not been changed from these two pulls. 29deg.
Nathan. We will strap the car down tonight and do another hit. Maybe another set of eye and ears will pick up something..
Old 04-28-2016, 09:28 AM
  #51
9sectruck's Avatar
The initial hit on street and dyno around 2800rpm the car will go 12.0afr then climb straight to 12.6-12.7afr. Timing ramps in from 22-25 up to 29 by 4900rpm
Old 04-28-2016, 09:33 AM
  #52
9sectruck's Avatar
i cant help but notice the thread down from falxzzr that seems to have similar issues at high rpm. Same dyno and tuner, and if the afr and spark are what they are, is it possible the dyno has an issue at high speed or is there examples from that dyno where they'll pull cleanly to something highish. He also has a new motor, was the same builder the one who put your cam in?
yes i built both cars. And tuned both. Op car was done 3-4yrs ago on street tuning and fallzer was done on dyno this last month...
Im not the big name tuner by any means. But doing for about 6yrs now. (knock on wood just blowing my own **** up) nobody elses.
I find the stopping points with my own car.. Lol
Old 04-28-2016, 09:43 AM
  #53
If it needed more fuel on the big end, doesn't that mean it's making more power which necessitates more fuel, or am I wrong there.
Old 04-28-2016, 09:48 AM
  #54
9sectruck's Avatar
The very last graph with dyno recalibrated. This after re-tuning car with more fuel up top to get afr back in the 12s. The car still falls off at 57-5800rpm. Im going to scan map readings on the car with key on not running to verify the map is around 102-105kpa then do another pull with car and see if the car is pulling vacuum. (90-98kpa) this should tell us if intake is choking the car down.
Old 04-28-2016, 09:49 AM
  #55
9sectruck's Avatar
Yes nathan it should. More air more fuel should have net more power
Old 04-28-2016, 09:56 AM
  #56
slow trap's Avatar
i don't have the graphs but mine has the same issue of dropping off quicker up top now than with the 1 3/4" headers. it really sucks dropping time and money into mods that in reality should pick up power but they wind up not doing squat. now i may also be thinking ddnspider may possibly be onto something. we need the cam gurus and advanced fellows in here to help.
rise of the phoenix's car on the same dyno carried better with the 1 3/4 " so i doubt it is the dyno.valve timing and over scavenging may be the issue but i would hate to change cams and still not be where it needs to be.heck,look at people claim true duals with an x pipe helps scavenging and picks up power.i am lost on my setup as well as one like this guy's. good luck on finding your lost h.p bro.
Old 04-28-2016, 10:00 AM
  #57
ddnspider's Avatar
Not knocking you as a tuner by any means. If anything a setup like this on a dyno is cake to tune especially at WOT so I doubt its an issue in the tune.
Old 04-28-2016, 10:03 AM
  #58
I sent the dyno graph to Brian Tooley this morning to get his opinion on whether or not it's the cam causing this.
Old 04-28-2016, 10:05 AM
  #59
Kent, that sounds like a good idea. It will help narrow things down for sure.
Old 04-28-2016, 10:30 AM
  #60
fst100's Avatar
something else to think about since you had mentioned cam overlap which sounds interesting.
http://www.lunatipower.com/Tech/Cams/CamSpecTerms.aspx
particularly under the "What does it do?". makes one wonder that a cam with 111 like a MS4 make topend power would then need to rev really high (with a lift .649/.609 IIRC) along with proper gearing make power, right?
Quick Reply: "The Mongoose" - 1 3/4" Headers To 1 7/8" Headers (447 rwhp and 431 rwtq)
