Cam only ls2 w/ BTR stage 3 NA
Old 11-23-2016, 02:35 PM
Cam_OnlyTA's Avatar
Default Cam only ls2 w/ BTR stage 3 NA
Just threw this little combo together and thought I would share the results. Doesn't seem too bad for what it is. Here's the mod list:
40k mile LS2 in an M6 Fbody
BTR stage 3 na cam
BTR 3/8 pushrods
BTR platinum Springs w/ ti retainers
Comp r lifters
Ported ls6 oil pump
Ls7 chain
Holley 102mm sniper intake manifold
Nick Williams 102mm TB
SD tuned
42lb injectors
1 7/8 Longtubes w/ open y pipe
ASP Underdrive pulley
4.10's
Old 11-23-2016, 04:39 PM
BBWS6's Avatar
Not bad at all. I wanted to ask what would I need to swap the LS1 with an LS2 on my 4th gen? I'm really considering getting one.
Thanks
Old 11-23-2016, 05:40 PM
SoFla01SSLookinstok's Avatar
Nice looking curve!
Old 11-23-2016, 06:00 PM
Cam_OnlyTA's Avatar
Thanks
It's not too bad. I just swapped all the fbody acc and oil pan over. Only thing after that was drill the block for the dip stick tube and get the extension harness' for the cam and knock sensors.
Originally Posted by SoFla01SSLookinstok
Nice looking curve!
Thanks!
Old 12-06-2016, 08:56 PM
WVhuggerSS's Avatar
Nice results looks like power was still climbing, have any pics of that intake on car?
Old 12-16-2016, 12:34 AM
DavidBoren's Avatar
If you have trunnion upgrades in your rockers, I would push that to 7200-7500rpms. Pretty solid combination, I bet it's fun.
Quick Reply: Cam only ls2 w/ BTR stage 3 NA
