The Blazemobile Hits the MTI Dyno For Check Up
Old 03-20-2005, 07:33 AM
blazeone's Avatar
Default The Blazemobile Hits the MTI Dyno For Check Up
My MTI heads and cam package "C2 cam with Stage 2E heads" was installed in August of 2004 and dynoed then at 417rwhp corrected.
I thought I'd take it back and have it checked out since it's been 7 months. MTI's Wideband setup confirmed the A/F ratios were right on. Made even more power only change has been adding the Exedy Hyper Single clutch. The clutch/flywheel assy did drop off about 15 lbs if I recall correctly.
Anyway "Drum Roll" 426rwhp and 400ft/lbs torque corrected and 432.6rwhp and 406.5ft/lbs torque actual.
