What Affects dyno results?????
Old 04-18-2006, 06:24 PM
00' WS6 T/A's Avatar
Question What Affects dyno results?????
The other night, I got into an argument with my roomate about what effects dyno results and also he said that HP means nothing. Torque is everything in a car and you dont even need any HP. Please post what you all think about the two subjects.........Later
Old 04-18-2006, 07:17 PM
DynoDR's Avatar
HP is just TQ referenced by RPM. You know HP=TQxRPM/5252.
You cant have one without the other.
Old 04-18-2006, 07:21 PM
383LQ4SS's Avatar
right...but TQ is the ONLY thing that can be directly measured. Thats why people say that TQ is everything. You can directly measure a TQ value.
HP will always be derived from atleast two factors...wether TQ and rpm, rpm and time, etc etc...but it will always be two.
Old 04-19-2006, 09:02 PM
black97ss's Avatar
dyno effects can be my temperature, humidity, a/c on or off, sea level, texas dynoes wayy higher than like colorado etc. and torque and hp go hand in hand just as what was said
Old 04-19-2006, 09:28 PM
Redline-Motorsports's Avatar
Thats why we try to dyno with as close to same conditions "as" possible. This at least removes some of the variables. The key to properly using a dyno is to stay with the same dyno as you build you project. No two dynos read the same so its tough to internet compare all the time. We have a Dyno Dynamics Eddy current brake dyno in which it incorporates an actual torque sensor. It really measures torque as opposed to calculating it out through a rotating mass. This "true" reading and referenced with the injector pulse (for rpm signal) really increases repeatablity and accuracy!
Old 04-20-2006, 08:52 AM
dynocar's Avatar
If the dyno is properly operated using the normal SAE 1349 Rev 90 correction factors, this negates any differences in dyno elevation and atmospheric condition differences.
Old 04-20-2006, 11:02 AM
dynocar,
What does SAE define as the 1349 Rev 90 correction factor values?
Old 04-20-2006, 11:49 AM
dynocar's Avatar
Originally Posted by Redline-Motorsports
dynocar,
Air 77 deg F, Bar pr 29.235 "Hg absolute, humidity 0%.
