dyno'd my SS with NOS
well here are my dyno sheets with a 100 HP shot of nitrous. i have a dry kit with a progressive nitrous controller. the window switch has the nitrous come on at 4,000 rpm's and i have the initial hit come in at a 50 HP shot and then in 1 second of time it ramps up to a 100 hp shot. my camaro has a turbo 400 trans with a unlocked 3,000 stall converter. the stock 10 bolt rear end has strange 3.73 gears and a auburn posi.
so yeah if i still had the stock manual trans in the car with the stock 3.42 gears it would have dyno'd like way higher. but this is a track car and not a dyno queen. i have a strange 12 bolt rear on order with 4:10 gears that will be goin in next month. i think with this setup i should be able to run a 11.20 @ 122 mph at a track near sea level.
my best time of 12.24 @ 113 mph before i had the nitrous was done at a track that resides at 3,075 feet above sea level. the corrected density altitude on that run was over 5,000 feet above sea level.
Originally Posted by yak
how did you dyno 453 rwtg without the bottle>?
here is the dyno sheet from back in january b4 the NOS was put on and i was running the hotter spark plugs. as you can see 2 pulls were made with different A/F ratios as well. if you run to rich you will lose power as this illustrates. xtreme motorsports uses HP tuners to dyno tune my car.
