My Old Sts Dyno
looks like you need more fuel. The maf can't be maxed there are people on here with 15+ psi with the stock maf. Plus at wide open the maf isn't used PE is. Looks as if you need a better fuel system.
Could be maf max, or fuel pump or injector max. It also looks like there may be a valvespring issue. Disregard what the guy said two posts up, the maf IS used at wot. The map isn't even used over 4krpm. Also, there is noone with an ls1 running 15psi on a stock maf without involving one or more of a variety of tuning tricks to work around the limits.
