'02 Z28 w/PTB dynoes@298...w/SLP lid dynoes@303...w/SLP lid & SSRA2 dynoes@318!
'02 A4 Z28 w/PTB dynoes@298...after SLP lid, dynoes@303...after SSRA2, dynoes@318!
I have a 2002 Z28 with the A4 and around 54,500 miles. The actual baseline dyno is in my sig and was performed at TT Performance in December 2004 using their dyno jet. The following is a summary of the dyno runs that were performed on 11/11/06 at Harris Speed Works using their dyno jet. All 9 runs were made within an hour. All 9 runs were made on the same dyno. The weather condition is on the linked dyno graphs. This was an open hood dyno with a fan blowing air towards the radiator area from an angle beneath the car.
With Thunder Racing's Ported Throttle Body:
Run #1: 295.2 Max HP, 346.4 ft-lbs, 12.9 a/f
Run #2: 296.8 Max HP, 341.9 ft-lbs, 12.9 a/f
Run #3: 297.7 Max HP, 345.9 ft-lbs, 13.1 a/f
With Thunder Racing's Ported Throttle Body & The SLP Lid:
Run #4: 300.6 Max HP, 352.7 ft-lbs, 14.0 a/f
Run #5: 300.8 Max HP, 352.2 ft-lbs, 14.0 a/f
Run #6: 303.3 Max HP, 353.0 ft-lbs, 14.0 a/f
With Thunder Racing's Ported Throttle Body, The SLP Lid & Al Austin's SSRA2:
Run #7: 317.8 Max HP, 358.5 ft-lbs, 14.1 a/f
Run #8: 316.8 Max HP, 356.5 ft-lbs, 14.0 a/f
Run #9: 315.9 Max HP, 360.4 ft-lbs, 14.0 a/f
I can't wait to take this car to the dragstrip. I think I can get at least a 110 MPH trap speed in really good weather.
not to burst your bubble or anything, but comparing numbers from two different dynos doesn't really do you any good. Each and every dyno is different. A magazine once tested around 10 dynos with the same car in similar weather and there was a 70 hp difference between the lowest and highest numbers.
Originally Posted by damon_Z
You didn't burst my bubble. You should have read the whole thing. The baseline used in this dyno session was the first three runs. All 9 runs were made on the same dyno.
I did read that, I was just pointing out that dynos are different and just because you dyno that, doesn't mean you'll trap 110. Also, 14.1 a/f ratio is kinda high...isn't it?
Yeah, I understand you now. It looks like the SLP lid leaned me out, but the mandatory dyno tune is in store for the near future. I just have to upgrade the whole exhaust system first...
Yea, 14:1 is pretty lean, thats how the MAF gets you the power, once you richen it up you'll lose some. Great numbers regardless though. You may not trap 110 though, ALMOST trapped 112 and I'm making 400 RWHP. However, it was my first time out, but I doubt my MPH will be affected much, just take her out and see, if your not satisfied add some more stuff!! Good luck.
hmm...maybe i should have my car dynoed, thats lil scary that it would do that. was there any detonation?
Originally Posted by 92SilverSHO
the tq seems pretty high for what you have.
Happy with my SSRA as well. They advertise a gain of 13rwhp at a simulated 50mph and obviously your car likes the SSRA Did you have a very high powerful fan under it?
Yup. I just realized that. The baseline torque numbers are around 30 ft-lbs more than my baseline number from another dyno jet. I'm trying to get to the bottom of this...
back to the top...
Originally Posted by GOaT Cheese
You stated that the the 9 runs were with hood up. Was the run in your sig with the hood up? I'm sure you are aware that the "hood up" is a trick dyno opperators use to boost h.p. output. The hood being down will kill 15-20 RWHP.
Yup. I don't think I've ever seen a dyno performed with the hood down.
