mechanical oil pressure test port
like the title says i'm looking to borrow or buy a mechanical oil pressure gauge and port that installs where the oil pressure sender goes on the back of the block. i need to check oil pressure on the GTO. if anbody local has one i would only need it for a couple hours. thanks in advance
Matt
Matt
1 Post
I think you might be better off tapping into the the drivers side front of the block just under the head. There is a big ole plug there... That is where I run my mechanical oil pressure gauge from... Good luck to you...
Here may be some good info for ya....
http://forums.corvetteforum.com/c5-t...elocate-2.html
