Florida Members Fun, sun and LS1's
lq4 to ls2
Old 05-18-2011, 12:28 PM
camross998's Avatar
Default lq4 to ls2
what would it take to convert a lq4 to ls2 well the problem is i got a 99ws6 with bad connecting rods i got a lq4 motor with head 317 out of a 2003 pick up i was gonna set the motor up for a procharger but now im like i would just rather do N/A but my question is im look for like 400 whp the car is a A4 also what ami looking forward to make tht happen
Old 05-18-2011, 12:55 PM
67RSCamaroVette's Avatar
You can put some small chamber 241 heads on it, and get over 400rwhp with the pistons that are in it and a small cam.
If you want big N/A power, flat top LS2 style pistons, L92 heads, L76 intake, and a 224/230 cam will net you 460-470 rwhp. Lashway Motorsports is about 15-20 minutes north of you if you aren't looking to do the motor swap yourself, and they can dyno-tune it after the swap to squeeze every bit of power out of it. If you need a hand with heads/cam install on the LQ4, I'm pretty local to you, and have done lots of heads/cam swaps, have all the tools, pushrod checker, timing wheel, crank socket, etc..
Quick Reply: lq4 to ls2
