Need crank reluctor alignment tool in SFL
I have an LY6 crank with a 58x reluctor ring which I need to change over to a 24x reluctor. I have a brand new 24x reluctor already in-hand.
Does anyone know of a place that will rent the Goodson crankshaft reluctor ring alignment tool?
Alternatively, is there a local shop that will do the recluctor ring swap?
Palm Beach or Broward area preferred, but willing to go a little farther if I have to.
have not heard people doing this. but alot of people just buy the converter box.which saves them the trouble of taking the crank out. i will be using the box on my ly6. after i find a new oil pan, and front cover
I chose this over the converter box because the crank was already out, and the converter box is $250 versus the reluctor ring which was $17. Also, less wiring and one less failure point.
I had the 24x reluctor put on today. Took them all of 10 minutes to remove the old one and install the new one. They used a torch and the Goodson alignment tool. They also cleaned and polished the crank for good measure.
Do you need to also change crank snesors from greay to black or vissa versa?
Also does anyone no of a 2x cam sensor on the top back of the motor like the 1x cam sensor?
Going a differnt route going to keep it 24x.
Update:
Since originally posting, I spun a rod bearing and bought a new crank. Of course the new crank came with the 58x reluctor wheel already installed. So I had to take my old 24x and swap it onto the new crank.
This time around I did it myself. I used a MAPP torch to expand the wheels to remove/install them. I eyeballed the alignment. You just need to align the holes in the wheel which look like this C> with the flexplate/flywheel bolt holes.
I've put over 500 miles on the engine so far and have not even done a crank relearn yet. It's running perfectly.
Just proves you can do it yourself without the special tool.
Here is the 24x installed on the new crank:
The new crank with 58x, old crank with 24x:
The new crank (58x):
The old crank (24x):
The following users liked this post:
Poor not Lazy (01-07-2021)
