boost help
Old 10-15-2008, 01:36 PM
john.boy1985's Avatar
Default boost help
hey guy just a question on how much boost in your opinnion could i run i know with fuel being a factor. its a 98 ls1 stock cam and lower end ,arp2000 rod bolts arp head bolts ,5 layer mls gaskets,i have a wabro 255 pump 42# injectors, the stock 806 heads ported polished 10cc taken out of the combustion chambers to lower compression and a intercooler with nitrous spray bar and water methanol the turbo kit is an hp performance stage 2 its a 67mm i know it made 9psi on a stock motor what will it do on my setup thanks
Old 10-15-2008, 02:39 PM
i know yal hear that all the time but i was thinking around 12psi befor fuel became a problem
