Upcoming Turbo Build Questions.
Location: Chitown-Jax NC-Jax FL-Honolulu-OKC, OK-NOW New Orleans Area
I am strongley considering doing a Turbo build on my 408 but not to certain about a few things and dont want the motor to go pop on my. I dont know all the details about the motor since I bought it from FFHP and never got a flow sheat and they went under. What I do know is that the car was built for TONS of Spray, running 11-1 comp. Has the TexasSpeed Giant cam in it, Patriot Stg 2 317s heads, Long tube headers, I have a AEM Wideband and for everything else just look at my sig..
I am about to get this:Garret 76mm Turbo compressor wheel
.55 A/R compressor housing
.96 A/R turbine housing
Journal, t4 flange.
Its brand new.
What I THINK I know I need.
1- Different heads but which ones
2- New intake?
3- Maybe new fuel rails depending on the intake
4- 60lb fuel injectors
5- Truck manifolds
6- blow down piping
7- blow off vlv
8- boost gage
9- Relocate battery to rear
10- Boost controller
11- thicker head gaskets to help lower comp. ratio
12- A second Fuel pump
Also how much boost is possible without blowing the motor?
I also am going to be replacing the fuel lines from front to rear so more fuel can flow.
I have incl. a pix of the engine bay to help show what is there and isnt.
I also have a built 6speed trans, stock 10bolt FOR NOW, getting a 9in in the spring.
Journal, t4 flange.
Its brand new.
2- New intake?
5- Truck manifolds
6- blow down piping
7- blow off vlv
8- boost gage
