A 383 OR 355 Supercharged?
Old 11-02-2008, 09:33 PM
Red1996SS1519's Avatar
Default A 383 OR 355 Supercharged?
I'm debating between a 383 or a 355 for my setup and need some advice.
I have a 195cc AFR heads, LT4 intake and a vortech supercharger/intercooler, 42lbs injectors and everything ready to install, just need to decide between a 383 or a 355.
Here are the specs of the 355 :
Brand new stock GM crank
Scat forged I-beams with arp 2000 bolts
SRP -24cc dished(low compression) forged pistons .030 over
plasma-moly piston rings gapped for boost
all clevite H-bearings
arp 2 bolt main studs
It's setup for 12-15 PSI.
My goal is to reach 600 WHP. Do you think this 355 would get me there or I will need a 383. Give me some advice on a 383 build if you think this 355 wouldn't do it.
Old 11-02-2008, 10:56 PM
DeltaT's Avatar
The 355 will get you there, but the added torque of the 383 will make the car a LOT more fun, sinc the Vortech hit is a strong mid-range and killer top end.
My 383/Vortech T-trim combo got me to 632rwhp/576rwt at 11.7# of boost. It's a 9.6:1 motor. Plan on upgrading to 60lb. injectors though for those power levels, and a solid alky system for insurance on hot days, crappy gas or racing.
Jim
My Site: http://home.mindspring.com/~jim_fisk/id1.html
Old 11-03-2008, 05:39 AM
Waw, very nice job there. Good points.
Old 11-03-2008, 11:06 PM
Is torque the only difference between the two choices ?
Old 11-04-2008, 12:39 AM
DeltaT's Avatar
The longer stroke works well with boost too. Larger bore unshrouds the valves a bit more so they breathe better. Larger displacement allows a bigger cam to still be streetable. That's all I can think of. Oh, and nowadays the price is pretty much the same, so why not go large? Size does matter, no matter what they claim
Jim
Old 11-04-2008, 05:41 PM
engineermike's Avatar
I agree with the others. Centrifugal cars are weak on low-end due to the characteristic of the boost curve. The added stroke helps the situation a lot. I too had a T-trim/383 combo.
Quick Reply: A 383 OR 355 Supercharged?
