Greddy EBC & Tial Sport Wastegates - Need Installation Instructions
I'm trying to get all my vacuum lines hooked up correctly to install my Greddy Profec B Stage II Electronic Boost Controller to my Twin Turbo setup with Tial Sport Wastegates.
The turbo compressor housing ports are blocked off. The Tial wastegates have two ports, one on top and one in the center of the side or tip however you look at it. Then the EBC has a vacuum line and the valve unit has two connections one labeled COM and the other NC. I also have two blow-off valves integrated in the charge pipes that go into the intercooler.
Can someone tell me which lines to run where to connect of this correctly. Right now my EBC is not controlling the boost and it is spinning up freely up to 10+psi. I have the EBC setting turned all the way down and I have no idea what psi springs I have in the wastegates.
Thanks for your help!
boost, controller, ebc, electronic, greddy, ii, install, installation, instructions, profec, setup, tial, twin, wastegate, work
