Cylinder Heads
Old 12-07-2008, 11:22 AM
mygto's Avatar
Default Cylinder Heads
Guys, Which Cylinder heads would you recommend for a 370ci forged short block. Trick flow 225 or Afr 225. Thanks for the input.
Old 12-07-2008, 12:27 PM
MY99TAWS6's Avatar
No dyno numbers till next year but no complaints with my afr 225s. Trick flo seem like good heads also. Can't really go wrong with either I would say. I am just a die hard afr guy.
Old 12-07-2008, 12:51 PM
mygto's Avatar
I think your right, I will just look for the best deal on either one.
Old 12-07-2008, 01:44 PM
MY99TAWS6's Avatar
I am pretty sure the trick flo require aftermarket rocker arms. The afr you can run stock rocker arms.I am running 1.8 yella terras to give my pretty mellow cam some extra lift.
