ms3 on f.i setup
Old 12-13-2008, 02:26 AM
pewter02z28gs's Avatar
Default ms3 on f.i setup
is anyone running an ms3 on an f.i setup and if so are there any down side cause i thinking about using the ms3 for my current na motor in my turbo build.
Old 12-14-2008, 09:37 AM
DVS99TRANS's Avatar
I would say go with something smaller. This topic has come up many times but is not the best cam for FI, not say it won't work. But the overlap on a MS3 is a bit much and something like a 228/228 or a 232/232 would be alot better. The 232 is still a bit big in my honest opinion, but to each their own.
Old 12-14-2008, 09:58 AM
lifeisgood's Avatar
i mean any thing can be ran w a blower its just not optimal.
too much overlap. the car wont be able to produce the power its capable of with better camshaft
Old 12-14-2008, 09:08 PM
Professor_speed's Avatar
get it on a 114 should be ok. I just pmed veee8 abut his turbo set up, and his is very close to that. 830hp at 13.8 psi through a turbo 400! (370 cubes)
Old 12-14-2008, 11:07 PM
67camaro's Avatar
Your guage wont show as much "boost", but the air flow and power will still be there. I would try it especially if you will be staying with the stock compression. I also just noticed you're running a 6.0 so the extra cubes will help with spooling that turbo.
Quick Reply: ms3 on f.i setup
