oil pan ?
Old 12-20-2008, 08:07 PM
02 z/28's Avatar
Default oil pan ?
Is there any advantage in using a canton oil pan(wet sump) over a stock oil pan spinning the motor to 7000rpm?or should I spend 850 to get the moroso setup? let me know what you think.
Old 12-21-2008, 12:26 AM
DeltaT's Avatar
If you are only spinning to 7K, I'd go with the Canton pad and the right pickup to match. They have a windage screen and IIRC a crank scraper option. And it will only be like $300-400. I used one in my 383 and have another going on my new 434/Whipple 3.3.
Jim
