what size pulley for 12 lbs
Old 01-01-2009, 07:42 PM
charged 434's Avatar
Default what size pulley for 12 lbs
i have a f1c with stock ls1 heads ported on a 347, my crank pulley is 7.75 in what size blower pulley do i need to get around 12 lbs
Old 01-02-2009, 04:01 AM
EPP
EPP's Avatar
How much boost the blower can produce depends on many variables.
* Cubic inch. The larger the engine the less boost it will make with a P-1SC.
* Headers and exhaust. A better flowing system will produce less boost, requires a smaller pulley to regain the loss in boost. Ultimately though, more power will be gained.
* Camshaft and heads. A camshaft with some overlap will leak out some boost through the valves. Better flowing heads react a lot like a better flowing exhaust system.
* Altitude. Elevation plays a big part in how much boost is produced. Those people living in the higher elevations have to spin the blower harder to see boost.
* Condition of engine. An engine with real good sealing rings will ultimately produce more boost than one with worn rings.
* Rpm. An engine that is spun up higher in the rpm range will normally produce more boost. Bob
Quick Reply: what size pulley for 12 lbs
