Camaro 3.4 with a 3.8 supercharger?
Alright i have a v6 camaro 3.4 (5 speed) and well it been sitting for a while and well my buddy just fucked up his engine cuz water got in but the injectors and supercharger off buick are fine if i switch the supercharger on to mine will it fit? and if so how do i make it fit
it will not be as easy as just popping stuff on. also you have to consider the strength of the 3.4 and the fact that it was not built for boost. and i am pretty sure that the intake for the supercharger will be hitting your firewall and will need to be modified, and the hood will not clear the supercharger. (you will need to cut a hole or get an aftermarket hood.) and swapping your 3.4 for a 3.8 supercharged will arise the same problems. and you will need to get the car tuned and figure out a way to run the belt to the supercharger. jsut save yourself money and buy an ls1 camaro or a bird
