EGT's
Old 01-04-2009, 05:23 PM
cbr600rx7's Avatar
Default EGT's
What kind of EGT's are you guys seeing on your turbo set ups and where does the temp start becoming a issue on the LS1. I know on my truck i like to keep them below 1050 and below 1200 when towing at the max but i would expect it to be a little different on a aluminum gas engine.
This is not on a remote system like STS i would expect there temps to be a little lower due to there set up.
Old 01-04-2009, 06:27 PM
jfg455's Avatar
we have been seeing 800's cruising and up to 1400 undr full boost. A/F and around 11.8 and timing at 15* total under boost 8PSI pump gas no meth.
Old 01-04-2009, 06:29 PM
night ryder's Avatar
i have always been told to keep it under 1600 as 1750 or 1800 is when aluminum starts to melt. i know on alky engines they are around 800 at the end of the track
