who tunes there own turbo car
I tune my own stuff. Started playing with Tec 2 about 6 years ago on a built Conquest. Then Hex editing and burning EEPROM chips for DSM's. Then DSM Link. Played with EVOscan/ECU flash. Ditched DSM's and started playing with LS engines. HP tuners and Megasquirt is my thing now.
I have an *** load of various forced induction, tuning etc books. Read them, compare info, talk with others, The best is learn from experience.
I bought hp tuners about a year back so could practice with it NA. I am going to be making the jump to 3 bar speed density in the spring when bring car out of storage.
Don't forsee any big issues. Hptuners has a forum and there is tuning section on here and on their forum you have some example tunes to work with.
I do know some local guys that are wizards on hptuners so if get over my head will just have to pay them . I find wot tuning is pretty easy but part throttle and speed density looks a bit trickier.
But at least got car running with base tune. I just set my max timing to like 12 for now and afr targets to like 10.5. I was not going high boost or even holding boost for more than brief time as my fuel system is not finished yet be ordering it as well shortly.
I tuned my car NA in Speed density first, then jumped to 2 bar. Had a little help from some friends, did a lot reading on the web, etc.. I still don't really know what I'm doing, but enough to make the car run pretty well and not blow up is good enough I guess. Just heir on the side of caution.
im tuning mine right now, i had never touched hptuners until after i put the turbo on. the biggest thing is to take it slow and really learn how to use the scanner. usually if you run into a problem someone on here can set you straight pretty quick.
read everything you can find on the subject
