SDCE bracket or COG set up for F1A 6spd street car?
Old 02-01-2009, 11:22 AM
jeremym's Avatar
Default SDCE bracket or COG set up for F1A 6spd street car?
SDCE bracket or COG set up for F1A 6spd street car? I will only be runnning 14-16 lbs.(825+rwhp) I do not want any belt issues. I also dont want to change the belt every month. I know turbos is the way to go. I have heard alot of good things about the SDCE bracket. So if anybody has either of these set ups please chim in and help me with any info. Thank you
Old 02-01-2009, 11:58 AM
stevensLS1's Avatar
https://ls1tech.com/forums/new-produ...available.html
Might want to check with Bob and the guys at EPP.
Old 02-01-2009, 01:01 PM
AFASTYZFR1's Avatar
dont think you can use cog drive with 6-speed
Old 02-01-2009, 02:43 PM
93formto98T/A's Avatar
I am running a COG setup with my F1R/F2 street car 6speed setup. If I had an F1A I would run the SDCE. You can run a cog setup with an M6 if you have the ATI SuperPulley on the blower. Think if it as the rear freewheel on a bicycle. It accelerates with increased engine RPM but let off the gas and it freewheels and coasts down. This will save a cog/M6 setup and is great for keeping boost between shifts cause it doesn't have to work to spin the impeller through it's entire range to come back up to speed.
Old 02-01-2009, 02:46 PM
stevensLS1's Avatar
Great info!!
Sick new ride btw!!
Old 02-01-2009, 04:11 PM
bigsticksupra's Avatar
ive heard great things about the SDCE set up
Old 02-01-2009, 04:21 PM
Originally Posted by stevensLS1
Great info!!
Sick new ride btw!!
Thanks bro, it's not quite finished yet. Hopefully in May. I'll put up a build thread soon.
Old 02-01-2009, 04:24 PM
AFASTYZFR1's Avatar
My sdce works great....doesn't slip at all at 16 psi with stock heads (3.4 blower pulley)........as soon as I get heads, I am going to max out my D1sc with a 3.0 reichard pulley and 7.25 crank pulley
Old 02-01-2009, 06:15 PM
jeremym's Avatar
I dont mean to sound dumb but what does that all mean?
Old 02-01-2009, 06:21 PM
venom ws7's Avatar
jeremym You need to talk to Bob at EPP believe me he will help you out big time.
With your 414ci and F1A I'm sure the car carn get high 700 low 800 rwhp on pump gas
and I dont thing you need COG setup with that boost.
Old 02-01-2009, 06:25 PM
jeremym's Avatar
How long does your belt last? Are u auto or stick?
Old 02-01-2009, 06:31 PM
AFASTYZFR1's Avatar
Stick......never had to replace belt yet.....I have around 5k on this one and don't think I will have to replace it anytime soon
Old 02-01-2009, 06:45 PM
venom ws7's Avatar
You worry to much about belt slipping if the install was done right you wont see any belt slip.
I have a freind with D1SC and crappy 6rip pulley and he's not seeing any belt slipping.
Just go for it I wanna see that with F1A Cough"" Video"" Cough
Old 02-01-2009, 06:51 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
You can't go wrong with the SDCE set up. Too bad they still owe tech advertising fees.
Old 02-01-2009, 11:46 PM
LS1Tech Sponsor
Slowhawk's Avatar
The SDCE will be fine. We run the stock style 8 rib setup on F1a and F1c setups with no slip.
Old 02-05-2009, 06:34 AM
jeremym's Avatar
Anybody else using the SDCE bracket?
Old 02-05-2009, 07:35 AM
I have been using the bracket since 05. Used it with a P1SC and now with a D1SC. Pricey but its one of those things where you only have to do it once to get it right.
Old 02-05-2009, 11:38 AM
618HAWK's Avatar
I am running it with no issues, with a F1a before that was with the D1.
I managed to install it with a 7.625 crank pulleyl, was not to crazy about the 7.25 crank pulley, Running a 3.7 on the blower. Still waiting on a tune so no Idea at the moment what the max psi is at.
Old 02-05-2009, 11:52 AM
dschmittie1's Avatar
I am running a SDCE tension I have had it for a year now and bout 5k miles. no problems yet
Old 02-05-2009, 12:08 PM
crashinaz's Avatar
Well, I'm going to the COG since I'm running track only and loose coverter auto. Haven't put it up for sale yet, but I'll let my 12 rib setup with 2 new belts go for about half of what the SDCE goes for... You'd just have to make your own standoffs. Just throwin another option out there.
Attached Thumbnails SDCE bracket or COG set up for F1A 6spd street car?-pulley-001.jpg
Quick Reply: SDCE bracket or COG set up for F1A 6spd street car?
