Vacuum line questions (for boost gauge)
11Second Club
Hey all,
My car went to the tuner yesterday for the new D1SC setup. On the first pull, the boost gauge showed zero, but it did show vacuum at idle. The way I had run the vacuum line was this...
There's a vacuum line going from the back of the intake manifold to a sensor mounted on the driver side of the intake manifold just next to the fuel rail. Then, there's another line going from there to something I've deleted (and I don't remember what). I had that line capped off. When I installed the boost gauge, I fed that output to the sensor.
The tuner said that this wouldn't work. He said the boost gauge sending unit wouldn't see boost through the stock sensor I was feeding it from. They pulled the line going from the back of the intake to that sensor and plumbed it directly to the sending unit for the boost gauge instead. This leaves me with several questions:
1) What is the sensor that had both an input and output that I was feeding the vacuum lines through?
2) Will deleting that sensor throw codes or screw with inspection?
3) What is it that I deleted? The sensor in question #1 had an output vacuum line going to whatever it is I deleted.
4) Why did the boost gauge sending unit not see boost through the stock sensor but did see vacuum?
Thanks in advance.
Thanks in advance.
