Head talk
Old 02-16-2009, 04:52 AM
trnsfmr99's Avatar
Default Head talk
Hello again!! Need yall's opinion on this. I'm about 2 weeks away from purchasing my turbo kit from Kentucky Turbo. However, I have a stock internal LS-6 motor with LS-1 heads. I did some shopping, but need some guidance on if I need to purchase some heads before the turbo kit. Please advise. Thank yall for input!
Old 02-16-2009, 09:34 AM
cbr600rx7's Avatar
You will be fine with the stock heads. If you are running the LS6 cam you are in luck as well. Probably the only thing that might be a issue is your stock valve springs if you have high exhaust back pressure.
Old 02-16-2009, 11:51 AM
trnsfmr99's Avatar
I'm doing well then, cbr600rx7. We upgraded the valve springs when we changed the cam a year ago (double spring setup). Thanks for your input. Really appreciate it!!
Old 02-16-2009, 01:07 PM
cbr600rx7's Avatar
You should be good to go then. The LS6 cam seams to do a little better on boosted cars vs the LS1 and the double springs should prevent any back pressure issue's.
Quick Reply: Head talk
