wastegate exhaust questions
12 Second Truck Club
I'm thinking of running a separate exhaust for my wastegate. i found a 1.5" bike muffler that is about 12" long. is that too small of a pipe? my waste gate it 38mm which is smaller than 1.5"s. i just want to make sure its not going to cause boost creep.
i have decided to do this do to the fact that i gained a lot of power suddenly one day. i had to add a lot of fuel at WOT. i found i had lost a bolt on my waste gate and it has a leak between it and the down pipe. i would like to keep this new found power but not the noise. so i found these mufflers. they are $36 for two of them. i figured i can hook them together and it would sound better.
your gate is huge compared to mine. how hot would the wastegate exhaust pipe get? i could run a 2" or so pipe to the back but it will be close to my trans. i guess it would only get warm being that the gate is not open all the time.
i found cherry bomb makes a 2" muffler that has a 3.5" body. they are like $32 on ebay. i think i'm going that route. its small and i can route it by my 4" exhaust.
For a real increase in power don't dump the WG separately. Put a big enough spring in it so it never opens in the first place, lol
Are you guys running restrictive exhaust systems? The only reason I can think of you would pick up power by dumping the WG is not enough flow in the exhaust. Or is there something I'm missing here?
